The UAE’s national e-invoicing system entered its pilot and voluntary phase on 1 July 2026. Businesses with annual revenue of AED 50 million or more face a hard mandatory go-live date of 1 January 2027, and even smaller businesses need to begin preparing now. PDF and paper invoices will no longer be accepted for B2B and B2G transactions once the mandate applies.
What changed
The UAE officially launched the pilot phase of its national e-invoicing programme from 1 July 2026, led by the Ministry of Finance and supported by the Federal Tax Authority (FTA) as part of the UAE’s broader digital transformation strategy.
The Ministry of Finance said the unified e-invoicing system would add value for businesses and government entities by reducing costs, improving operational efficiency and enhancing accuracy throughout the invoicing cycle. By automating the creation, exchange and verification of invoices, companies will be able to process transactions faster and strengthen cash flows.
The pilot programme involves selected businesses in a Taxpayer Working Group to test the system under Ministry and FTA supervision, and any business may opt in voluntarily from 1 July 2026.
The mandatory rollout then follows in phases:
- Large businesses with annual revenue of AED 50 million or more must appoint an accredited service provider by 30 October 2026, before mandatory implementation starts on 1 January 2027.
- Businesses with annual revenue below AED 50 million will have until 31 March 2027 to appoint an accredited service provider, with mandatory implementation beginning on 1 July 2027.
- Government entities are required to appoint a service provider by 31 March 2027, before joining the system from 1 October 2027.
One deadline was recently adjusted: in May 2026 the Ministry of Finance extended the ASP appointment deadline for businesses with revenue of AED 50 million or more, from 31 July 2026 to 30 October 2026. The mandatory go-live date still remains 1 January 2027.
What counts as an e-invoice? Invoices in the form of PDFs, Word documents, scanned copies, images or emails will not be treated as e-invoices. Invoices must be generated in XML using structured standards such as UBL or PINT-AE, transmitted via an Accredited Service Provider (ASP), and reported to the FTA’s e-Billing system.
How the system works: The UAE has adopted a decentralised Five-Corner Model where the supplier and buyer each connect to an Accredited Service Provider. The ASPs securely exchange validated invoice data, while required reporting information is made available to the FTA. This model encourages interoperability while maintaining security and privacy.
What is currently excluded: Business-to-consumer (B2C) transactions are currently excluded until further notice.
Penalties for non-compliance: Cabinet Decision No. 106 of 2025 sets out administrative penalties for non-compliance, including fines of AED 5,000 per month for failing to appoint an accredited service provider or implement the system on time, and AED 100 per missing or delayed electronic invoice, capped at AED 5,000 per month. Voluntary adopters will be exempt from penalties until mandatory implementation applies.
What it means for you
If your business turns over AED 50 million or more per year: The clock is running. You must have appointed an Accredited Service Provider (ASP) by 30 October 2026 and implemented e-invoicing by 1 January 2027. Prior to the appointment of an ASP, businesses must typically have conducted an impact assessment, performed vendor selection based on identified requirements, and outlined a project plan.
If your business turns over less than AED 50 million: Your mandatory deadline is 1 July 2027, but the voluntary phase is usually the smarter option for businesses that want to test their ERP, train finance teams, and avoid a January 2027 scramble.
For all businesses: This reform signifies a fundamental change in the way businesses operate, report, and interact with the FTA. By replacing traditional paper or PDF invoices with structured digital data, the UAE aims to enhance transparency, improve compliance, and boost efficiency across the economy. The UAE’s e-invoicing rollout is expected to affect businesses across sectors, requiring changes not only to accounting systems but also to areas such as procurement, tax processes, contracts and enterprise software systems.
Free zones are not exempt: If a free zone company is VAT-registered or falls under the Corporate Tax regime, the changes apply. Free zones are not exempt from proper tax governance.
What to do
- Determine your phase. Check whether your annual revenue is above or below AED 50 million, as this determines your deadlines.
- Appoint an Accredited Service Provider (ASP). Log in to the EmaraTax portal through the FTA e-services platform using UAE PASS. Inside EmaraTax, go to the E-INVOICING section, review the official list of pre-approved providers, choose your ASP, and click “Proceed to ASP.”
- Upgrade your systems. Implementing Peppol-compliant e-invoicing requires ERP adjustments, data cleansing, and integration with an ASP, all of which take meaningful time.
- Test during the pilot window. Businesses should test the system during the pilot phase from July to December 2026, checking if the ERP, ASP, and FTA systems work correctly together, testing sample invoices, and training employees to use the new process.
- Report system failures promptly. Notification to the FTA is required within two business days of any system outage.
FAQ
Do I need to comply if my business owes no VAT?
From 1 July 2026, all persons regardless of revenue can choose to implement e-invoicing voluntarily, and the scope is broader than just VAT-registered businesses. If a business is not already registered with the FTA, it will still need to obtain a TIN through EmaraTax before onboarding. Mandatory obligations depend on your revenue threshold and the phase schedule above.
Is a PDF invoice still acceptable after my mandatory date?
No. Once the mandate applies, VAT-registered businesses will no longer be permitted to issue invoices in unstructured formats such as PDFs or scanned copies. All invoices must be generated in a structured electronic format, typically XML, and transmitted via Ministry-approved Accredited Service Providers.
What if I was invited to join the Taxpayer Working Group pilot?
The Ministry of Finance contacts selected businesses directly, and a business joins the pilot only if it agrees in writing. If selected and accepted, the full technical requirements apply from that point. If you were not selected, you can still opt in voluntarily from 1 July 2026 under the same technical standards.
This is general information, not professional advice; always verify with the official sources linked below.
Sources:
- UAE Ministry of Finance, e-invoicing initiative: Request Rejected
- Federal Tax Authority, EmaraTax portal: https://www.tax.gov.ae
- Gulf News, e-invoicing pilot launch: UAE launches e-invoicing pilot phase: Key deadlines, five-corner model and what businesses must do to prepare
- Ministerial Decisions No. 243 and 244 of 2025 (via Ministry of Finance)
- Cabinet Decision No. 106 of 2025 (penalties framework)
